Nebula Cloud Service Incident 2022-06-20 12:59-23:41 (UTC+0)
Zyxel_CSO
Dear Nebula Users,
The system has been temporarily unavailable due to an outage incident.
Issue Started from:
2022-06-20 12:59 (UTC+0)
Resolve:
2022-06-20 23:41 (UTC+0)
Resolve:
Issue Symptom & Risk:
Some users have experienced
1. Some devices are offline and unable to reach NCC servers successfully.
2. Monitoring information will be abnormal on NCC.
3. NCC is unable to provision or update network settings to Nebula devices.
4. Nebula Site-to-Site VPN channel of some security gateway devices may not be established successfully.
Note: This outage incident does not affect Nebula devices and their local network services
If you observed any issues that do not match the symptoms & risks mentioned above, please contact @Nebula_CSO
We apologize for any inconvenience this has caused.
Zyxel Nebula Support
USG Flex series seem fine, but NSG devices are showing as down and unable to build VPN tunnels.0
Hi @Pook,
I have sent you the private message, but haven't received your reply yet.
We are still working on the Nebula service incident.
Please help to enable Zyxel Support at Help > Support request page and share your org/site name, so we can access your organization to check in our working hour later.
Thanks.
This is having a major impact at about a dozen of our sites. Content filtering isn't working properly and blocking legitimate sites, WiFi connections and broadcasts have stopped working. Symptoms are different at different sites. However, we can't address any of them due to the Nebula issues. Please provide a status update and ETA.0
This has taken up all of my day and looks like my night also. Lots of offline VPNs and configurations not syncing to the local device.0
Dear Nebula Users,
The incident has been resolved.
Resolved: 2022-06-20 23:41 (UTC+0)
I can confirm we are all back to normal, for us it only affected NSG appliances. USG Flex devices were fine.0
- 588 USG FLEX H Series
- 476 News and Release
