SSL Vpn client Win vs. Mac
Hi everyone,
I have a problem with a Mac SSL client on a ATP200 (latest Lab fw released in may): a home worker bought a new Mac AIO, installed the SSL client (latest version) and copied the configuration from the old Win client.
There is no way to be authenticated.
Win client works fine.
Have i missed something?
Just for clarification more than 15 people are using the VPN daily without problems (all win client)
Any suggestion?
Thanks in advance
Fred
Any suggestion?
Thanks in advance
Fred
Do you mean application didn't pop up so there's no way to authenticate ?
When the program is running, icon will be displayed on the top bar.
hi guys, sorry for the delay.Update: the issue seems to be related to the SSL port. On Atp SSL port is configured as 8443.
On Mac where ":8443" is added to public IP another port is automatically added as reported in screenshot.
If i restore port 443 in global parameters on ATP, (and delete :8443 on SSL Client) no more issue.
ideas?
Thank
Fred0 -
Hi @Fred_77,The 10444 port on Firewall is used for receiving the packets sent from SecuExtender.So client added it automatically.
If your HTTPS port has changed as 444, then it will display as: XXX.DOMAIN.COM:444:10444But it will not effects VPN connection issue.
Refer the Forum : https://community.zyxel.com/en/discussion/2568/ssl-secure-extender-on-mac
Could we have the remote session for issue check ?
Kevin0 -
Thank for your clarification @Zyxel_Kevin
can we schedule the remote session in the afternoon at 3.00 pm italian time zone?
Hello,I just found this thread, hopefully I have noticed I am not the only to face this problem.We also have the same issue here and connection cannot be made from Mac OS 10.14 with Zyxel VPN Client.The account works perfectly with a Windows agent.We a custom port number 10445 to connect to router.Can you please help us ?Thank you very much.0
Hi @LaboMGD,
Did you have the latest firmware ?
We had the issue on MACOS but we already fix in the latest firmware.Please find the following
https://community.zyxel.com/en/discussion/14386/zld-v4-72-wk35-firmware-release#latest
https://www.zyxel.com/global/en/support/download
Thank you
Kevin0 -
Hello Sir,Thank you for your reply.Here is the current firmware we use.My apologies if I was not clearer about this device brand I am using.I have checked the latest firmware (5.32) and it is mentioning the fix below.I'll let you know if this resolves the issue once USG is updated.Thank you.
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
