exFAT usb drive MOUNT
it seems that the NAS540 cannot MOUNT exFAT formatted USB drive automatically?
I was in the terminal -- and it seems that it has "mount.exfat-fuse" in the sbin folder?
Can I mount manually???
# mount -t exfat /dev/sd[x] /i-data/sysvol/exFAT_USB_DRIVE_name
??? is anyone know if this is going to work?
thanks
JIN :smile:
  • Mijzelf
    Mijzelf Posts: 2,395
    250 Answers 1000 Comments Friend Collector Fifth Anniversary
    AFAIK it should mount automatically. Did you check dmesg for errors, or did you try to mount manually? It won't hurt.
  • jin08611
    jin08611 Posts: 4
    I will try it again in few days I am currently uploading all my files to this new NAS I will post my findings in few days
    THANK YOU for all your awesome answers mijzel!!!   :smiley: :
