AM3100-B0 NAT Problems
BjornSch
in Home Router
Hi !
Any of you know how to add this configuration to NAT?
TCP: 3074,27014-27050
UDP: 3074, 3478, 4379-4380, 27000-27031, 27036
When I enter the Zyxel AM3100-B0 administration panel, I can only set the port, e.g. 3074, but I cannot set the range 27014-27050.
After changing the internet provider, the Zyxel AM3100-B0 router was delivered and installed. In the previous Router, I could select TCP / UDP and enter 3074, 27014-27050
In the Zyxel AM3100-B0 I can't
Please help
Please help
Hello @BjornSch
The user guide should help, but you need to register to download it from https://service-provider.zyxel.com/emea/en/products/fiber-oltsonts/active-fiber/hgus/am3100-b0
Kind regards,
Tony0 -
Hello Tonny!Thank You for Yours answer i try found solution there.
- 588 USG FLEX H Series
- 477 News and Release
