NAS326 V5.21(AAZF.11)
ctggladiator
Hello, since the new Firmware the mysql Service is not starting anymore:
Enable package "PHP-MySQL-phpMyAdmin" failed.
Does anyone has an idea?
Are you a bit comfortable with the command line? Login over ssh and try to start it manually. It might spawn a usable error message.You can find the package in /i-data/sysvol/.PKG/PHP-MySQL-phpMyAdmin/The startscript is somewhere in subdirectory etc, I think etc/init.d/PHP-MySQL-phpMyAdmin.Starting:/i-data/sysvol/.PKG/PHP-MySQL-phpMyAdmin/etc/init.d/PHP-MySQL-phpMyAdmin startupIf it doesn't show a usable error. you can try 'debug mode':sh -x /i-data/sysvol/.PKG/PHP-MySQL-phpMyAdmin/etc/init.d/PHP-MySQL-phpMyAdmin startup
Hello Mijzelf,
i tried the debug mode. it shows following result:/i-data/2824f7ff$ sh -x /i-data/sysvol/.PKG/PHP-MySQL-phpMyAdmin/etc/init.d/PHP-MySQL-phpMyAdmin startup+ PKGSTATUSFILE=/etc/zyxel/pkg_conf/status+ + sed s/ //gsed s/\/$//g+ awk -F: {print $2}+ grep Installed-Rule+ grep PHP-MySQL-phpMyAdmin /etc/zyxel/pkg_conf/status+ PKGVOLPATH=/i-data/2824f7ff/.PKG/PHP-MySQL-phpMyAdmin+ PKGLIBPATH=/i-data/2824f7ff/.PKG/PHP-MySQL-phpMyAdmin/lib+ PHPCONTROLFILE=/i-data/2824f7ff/.PKG/PHP-MySQL-phpMyAdmin/zypkg_conf/info/PHP-MySQL-phpMyAdmin.control+ IFCONFIG=/sbin/ifconfig+ BONDINTERFACE=bond0+ INTERFACEA=egiga0+ INTERFACEB=egiga1+ STATUSFILE=/i-data/2824f7ff/.PKG/PHP-MySQL-phpMyAdmin/config/PHP-MySQL-phpMyAdmin/PHP-MySQL-phpMyAdmin+ HTTPCONFPATH=/etc/pkg_service_conf/PHP-MySQL-phpMyAdmin.conf+ TMPCONFPATH=/etc/pkg_service_conf/PHP-MySQL-phpMyAdmin.conf.bak+ KEYWORD=phpmyadmin+ SQLPATH=/i-data/2824f7ff/.PKG/PHP-MySQL-phpMyAdmin/mysql+ NICE_VALUE=20+ HTTPD_TMP=/tmp/httpd_conf.bak+ PLAYZONE=yes+ PKGCONFIG=/etc/pkg_service_conf/httpd2.conf+ CHKMD5SUMLIST=/i-data/2824f7ff/.PKG/PHP-MySQL-phpMyAdmin/config/checklist+ PHPSOPATH=PHPIniDir /i-data/2824f7ff/.PKG/PHP-MySQL-phpMyAdmin/php+ PHPINI=LoadModule php5_module /i-data/2824f7ff/.PKG/PHP-MySQL-phpMyAdmin/lib/libphp5.so+ [ startup == getlink ]+ [ startup == enable ]+ [ startup == disable ]+ [ startup == shutdown ]+ [ startup == status ]+ [ startup == startup ]+ sqlite3 /etc/zyxel/upnp.db SELECT COUNT(*) FROM upnpInfo WHERE service='PHP-MYSQL-PHPMYADMIN_HTTP'+ UPNPCOUNT=1+ [ 0 == 1 ]+ NICE_VALUE=17+ mount --bind /i-data/2824f7ff/.PKG/PHP-MySQL-phpMyAdmin/mysql /usr/local/mysql+ cat /i-data/2824f7ff/.PKG/PHP-MySQL-phpMyAdmin/config/PHP-MySQL-phpMyAdmin/PHP-MySQL-phpMyAdmin+ STATUS=Disabled+ [ Disabled == Enabled ]+ disable+ [ xyes == xyes ]+ echo phpmyadmin+ echo RewriteRule "(?i)/pkg/phpmyadmin" "/zyxel/disable.html" [R=301]+ mv /etc/pkg_service_conf/PHP-MySQL-phpMyAdmin.conf.bak /etc/pkg_service_conf/PHP-MySQL-phpMyAdmin.conf+ + sed s/^DirectoryIndex index.html index.htm index.php$/DirectoryIndex index.html index.htm/sed s/^PHPIniDir /#PHPIniDir /+ sed s/^AddType application\/x-httpd-php /#AddType application\/x-httpd-php /+ sed s/^LoadModule[ ]php5_module/#LoadModule php5_module/ /etc/pkg_service_conf/httpd2.conf+ mv /etc/pkg_service_conf/httpd2.conf.bak /etc/pkg_service_conf/httpd2.conf+ grep phpmyadmin+ cat /etc/pkg_service_conf/httpd2.conf+ RESULT=AuthZyxelSkipPattern /phpmyadmin /webdav /favicon.ico /desktop,/cgi-bin/weblogin.cgi /desktop,/cgi-bin/file_download.cgi /desktop,/cgi-bin/dlnotify /desktop,/disable.html /desktop,/login.html /desktop,/ext/ /desktop,/css/ /desktop,/images/ /desktop,/loginwrap.html /desktop,/css/ /desktop,/dojo/ /desktop,/res/ /desktop,/js/ /desktop,/login.html /MyWeb/ /register_main/setCookie /playzone,/mobile_login.html /playzone,/mobile/sencha/ /playzone,/mobile/images/ /playzone,/images/+ [ AuthZyxelSkipPattern /phpmyadmin /webdav /favicon.ico /desktop,/cgi-bin/weblogin.cgi /desktop,/cgi-bin/file_download.cgi /desktop,/cgi-bin/dlnotify /desktop,/disable.html /desktop,/login.html /desktop,/ext/ /desktop,/css/ /desktop,/images/ /desktop,/loginwrap.html /desktop,/css/ /desktop,/dojo/ /desktop,/res/ /desktop,/js/ /desktop,/login.html /MyWeb/ /register_main/setCookie /playzone,/mobile_login.html /playzone,/mobile/sencha/ /playzone,/mobile/images/ /playzone,/images/ == ]+ touch /tmp/restart_httpd+ exit 0
Can you find the problem?0 -
+ cat /i-data/2824f7ff/.PKG/PHP-MySQL-phpMyAdmin/config/PHP-MySQL-phpMyAdmin/PHP-MySQL-phpMyAdmin+ STATUS=Disabled+ [ Disabled == Enabled ]+ disablelooks like the package isn't enabled. You can edit that file, or try to let the script do it:/i-data/sysvol/.PKG/PHP-MySQL-phpMyAdmin/etc/init.d/PHP-MySQL-phpMyAdmin enable
i tried the script. but the error is the same. Also in webgui i still cannot enable the service0
Hi @ctggladiator
Sorry for the inconvenience.
Currently, we're working on this issue and will update you here.
What a mess! Please repair phpmyadmin and sql database abilty ASAP. At the moment, my NAS326 is nearly useless without this.
Same situation, please fix it ASAP. As a workaround, is it possible to downgrade the firmware manually?dHeinz said:What a mess! Please repair phpmyadmin and sql database abilty ASAP. At the moment, my NAS326 is nearly useless without this.0 -
zacki27101 said:As a workaround, is it possible to downgrade the firmware manually?Yes. Download an older firmware here: ftp://ftp2.zyxel.com (as all major browser makers dropped support for ftp, you'll probably need an ftp client like filezilla), then login over ssh and executeecho 1 > /firmware/mnt/info/revisionThen you can downgrade by uploading a firmware file in the webinterface. (A .bin file).
Thanks for responding. But it is unfortunately not working for me. I downloaded '521AAZF10C0.bin' which is the version prior to the latest one (which worked just fine) and the webinterface responds with "The NAS firmware cannot be downgraded, please select a newer version of binary (BIN) upgrade file from your computer." Do I need a seperate/different file?Mijzelf said:zacki27101 said:As a workaround, is it possible to downgrade the firmware manually?Yes. Download an older firmware here: ftp://ftp2.zyxel.com (as all major browser makers dropped support for ftp, you'll probably need an ftp client like filezilla), then login over ssh and executeecho 1 > /firmware/mnt/info/revisionThen you can downgrade by uploading a firmware file in the webinterface. (A .bin file).0 -
You have to enter the command, "echo 1 > /firmware/mnt/info/revision" using SSH
then you can upgrade the firmware.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
