GS1900 at over 70% memory usage. newest firmware, factory reset,no config or devices connected
TRT
TRT Posts: 1 image  Freshman Member
edited August 2022 in Switch
Hello, i have bought a used GS1900-24, hard reset it and before even connecting any devices i notice it is sitting at over 70% memory usage.
it had firmware from 2015-2016.So i downloaded the newest firmware and installed it.
factory reset
And it is still sitting at over 70% memory usage with no devices and no config.
What could be wrong with it?
What can i do about it?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,623 image  Zyxel Employee
    edited August 2022 Answer ✓
    Hi @TRT
    Welcome to Zyxel community!
    There's nothing wrong with your switch.
    Normally, the memory usage of GS1900-24 switch is about 70 % in the default configuration, and it is because the switch runs some services like SNMP service, Syslog server, CLI, web service, etc.
    Zyxel Melen
  • Zyxel_Melen
    Hi @TRT
    Zyxel Melen
