LTE firmware for SBG3600
I should also like some firmware upgrades. Unfortunately my LTE module has never worked.
Current versions:
Gateway: V1.00(AAKO.4)
LTE: ALT3100_04_05_06_10_B8_LO0 -
Hi helgelk,
Please check your message inbox.
Regards,
Bob0 -
My question is not LTE related, but DSL:
my provider switched from DSL 17a to 35b.
is there any way to update the firmware, so that the SBG can establish internet connection?
BR Clemens0 -
My current firmware is "V1.00(AAKO.9)" and the current LTE firmware is "ALT3100_05_00_02_00_81_MS". Is there any update ? Could you please send them to me ?
Best regards,
Pascal0 -
SBG series was EOL in 2020 so there is no fw/path released anymore. Please kindly understand it.
How glad I am that I found a thread discussing this model! Old models have to be looked for as something forbidden! I will be VERY grateful if you give me the opportunity to update your device to the latest version! Dear Bob_C, send me too!😛
@Pascal, both are the latest.
@Ramses, check your message inbox please.
I have an issue and I would like to re-install the firmware V1.00 (AAKO.9) (or a later version if it exists). Can someone please send it to me?
Regards,
Pascal
Hi Pascal,
Regards,
Bob
I am kindly requesting the firmware version V1.00(AAKO.9) for the Zyxel SBG3600-N00 device.
Could you please provide a download link or send the file directly?This version is required for compatibility and testing purposes. If any additional information is needed to process this request, I will be happy to provide it.
Thank you in advance for your assistance.
- 588 USG FLEX H Series
- 477 News and Release
