NAS326 web gui stuck in NFS package update loop after fw update to 5.21
installed.list now reads:MetaRepository 0-013-0 Installed/MetaRepository_20160513_arm_013.zpkg
RandomTools 0-010-0 Installed/RandomTools_20160117_arm_010.zpkg
ffp 0-005-0 Installed/ffp_0.7_arm_005.zpkg
myZyXELcloud-Agent 0-0105-0 Installed/myZyXELcloud-Agent_1.0.5_arm_0105_326.zpkgfw is 5.21
is there a log from the webui to see where it's hanging please?The webui runs in the browser. So the logging should be in the browser. *Maybe* the browser console shows a clear error. (Ctrl+Shift+C in Firefox). But knowing ZyXEL there will be a lot of errors/warnings anyway.when i factory reset i'll lose the FFP, just busybox?The reset doesn't remove the packages, it just disables them. You can re-enable them in the package manager. (If the webinterface runs again)will telnet or ssh be ON by default?
Good question. The firmware telnet and ssh are disabled. So if the webinterface doesn't come up, you have locked yourself out.
A workaround could be an ffp stick, or the 'general purpose stick', which can startup telnet on boot.
ok so here's what firefox console shows, does this mean anything to you please? "temp is undefined".i will look into making an ffp stick and be sure i have that working before a reset. i will first try removing the other packages as you suggested (except ffp, becaiuse i really dont want to break ssh).out of interest, is it possible to update packages on the NAS by unpacking the files to the admin share and copying that into /sysvol/.PKG/? if so, what tools can open zpkg archives on linux desktop, anyone know? thanks! if this is impossible because they need to be installed on the box, is there a way to install zpkg archives with the command line on the box? thanks.0
removing the cloudagent package gives me more errors in console
. not sure if this is interesting or not?
but the first error with cloudagent package ENABLED (!) links to this. does this help anyone to understand the problem please?0 -
final error i'm seeing is in this:
Ext.define('MyDesktop.DownServicePref', {<br> extend: 'Utility.SubWindow',<br> id:'downPrefWin',<br> requires: [<br> 'Utility.Ajax',<br> 'Utility.MessageBox',<br> 'Utility.ShareBrowserWin'<br> ],<br> toolBarBtns:[{<br> text:'Apply',<br> fn:function(btn){<br> var currentActiveItem = Ext.getCmp("downPrefWizardCard").getLayout().activeItem;<br> if(this.isValidate(currentActiveItem.id)){<br> this.setAllData();<br> }<br> }<br> },
Im not sure which error is actually the problem halting the page!0 -
chromium shows more errors than firefox0
tried again disabling every package except FFP, for reasons explained above, afraid of losing access.here's where UI seems to be failing. can anyone decipher this please?
i'm suspicious of this cloudagent package.although Ive delete it from /sysvol/.PKG, it hasn't disappeared from the installed.list or installed folder on samba, and what's this?edit: yeah! it's reinstalling the cloudagent into .PKGs. im wondering if blocking the box from internet on my router might help?!edit2: tried blocking box from internet, didn't immediately fix problem but i really wonder if this cloudagent is the issue.0
zypkg.log ends like this2022-08-25 00:43:13 [ipkg][newver][5945]: [zypkg_get_installed_pkg_info][2438][ffp] strValue: "0.7zypkg005"
2022-08-25 00:43:13 [ipkg][newver][5945]: [zypkg_list_zypkg_newVer_contents][1346][ffp] Installed version: 0.7zypkg005, conf version: 0.7zypkg005
2022-08-25 00:43:13 [ipkg][newver][5945]: [zypkg_serialNo_comparison][1313] conf No: 005, Installed No: 005
2022-08-25 00:43:13 [ipkg][newver][5945]: ********* [zypkg_list_zypkg_newVer_contents][1336][gallery] start listing package "gallery" *********
2022-08-25 00:43:13 [ipkg][newver][5945]: [zypkg_get_installed_pkg_info][2420] open "" failed
2022-08-25 00:43:13 [ipkg][newver][5945]: [zypkg_list_zypkg_newVer_contents][1340][gallery] No Installed version, conf version: 3.0.9zypkg003
2022-08-25 00:43:13 [ipkg][newver][5945]: ********* [zypkg_list_zypkg_newVer_contents][1336][myZyXELcloud-Agent] start listing package "myZyXELcloud-Agent" *********
2022-08-25 00:43:13 [ipkg][newver][5945]: [zypkg_get_installed_pkg_info][2408][myZyXELcloud-Agent]strControlFile = /i-data/099df5e4/.PKG/myZyXELcloud-Agent/zypkg_conf/info/myZyXELcloud-Agent.control
2022-08-25 00:43:13 [ipkg][newver][5945]: [zypkg_get_installed_pkg_info][2438][myZyXELcloud-Agent] strValue: "1.0.5zypkg0105"
2022-08-25 00:43:13 [ipkg][newver][5945]: [zypkg_list_zypkg_newVer_contents][1346][myZyXELcloud-Agent] Installed version: 1.0.5zypkg0105, conf version: 1.0.5zypkg0105
2022-08-25 00:43:13 [ipkg][newver][5945]: [zypkg_serialNo_comparison][1313] conf No: 0105, Installed No: 0105
2022-08-25 00:43:13 [ipkg][newver][5945]: ********* [zypkg_list_zypkg_newVer_contents][1336][ownCloud] start listing package "ownCloud" *********
2022-08-25 00:43:13 [ipkg][newver][5945]: [zypkg_list_zypkg_newVer_contents][1340][ownCloud] No Installed version, conf version: 7.0.15zypkg004
2022-08-25 00:43:13 [ipkg][newver][5945]: ********* [zypkg_list_zypkg_newVer_contents][1336][pyLoad] start listing package "pyLoad" *********
2022-08-25 00:43:13 [ipkg][newver][5945]: [zypkg_list_zypkg_newVer_contents][1340][pyLoad] No Installed version, conf version: 0.4.9zypkg003
2022-08-25 00:43:13 [ipkg][newver][5945]: [ipkg_cmd_exec][3097] finish "ipkg_cmd_exec" with return value 0
2022-08-25 00:43:13 [ipkg][newver][5945]: [ipkg_op][892] clear pid file (11: newver)
2022-08-25 00:43:13 [ipkg][newver][5945]: [ipkg_op][928] ******** ipkg end with return value "0"
If an official Zyxel package doesn't install correctly (i.e. aborts or hangs during the installation process) or the web gui won't open after a (apparently) successful installation then you've downloaded and installed the wrong package. The downloaded package doesn't match with your device and/or firmware version.I had a similar issue on a NAS520 device where I could not install the NFS package or reinstall the PHP-MySQL-phpMyAdmin package.I learned that Metarepositiory didn't download these packages from the official Zyxel ftp servers.
<div><br></div><div><span># Official repository<br>ftp2.zyxel.com/+ ZyXELmirror<br>#Zyxel Global mirror<br>ftp.zyxel.com/+ ZyxelFTP</span></div>
(I guess these entries don't resolve properly. The Zyxel ftp site (ftp.zyxel.com or ftp2.zyxel.com) only offers NSA326, NAS540 and NAS542 and I use a NAS520. Obviously, the NAS520 packages are exactly the same as packages for the NAS540. Apparently MR can not find "NAS520 packages" )My fixI downloaded all the official packages for my device and firmware version (NAS520|fw v5.21, using the NAS540 packages) and uploaded them to my device and added the file location to MR.<div><span># Local repository<br>/i-data/b14a6a95/admin/backupzpkg/ Local_backup_ftp_zyxel_com<br></span></div><div></div>
/i-data/<unique number>/admin/<backup directory>Problem solved. All packages are (re)installable again.
- 431 Beta Program
- 2.6K Nebula
- 166 Nebula Ideas
- 6K Security
- 366 USG FLEX H Series
- 293 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 264 Service & License
- 408 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
