NAS326 web gui stuck in NFS package update loop after fw update to 5.21
Mijzelf, i'd like to kiss you right now, that exactly sorted my box out!MetaRepo updated as you said and now it all looks more or less ok here!Glad I didn't reset as wouldn't have known what was wrong, I always prefer to fix if possible.Lessons..1) disable old packages before updating, especially if unofficial packages.2) remember packages are stored on the hdd, not internal! so pulling the hdd is a quick easy check.any more?huge thanks man!0
turns out FFP actually has a warning about removing it before firmware updates. Oops! I should have done that then. Because i hadn't used for years, I forgot what i'd already done.
I'll see if I can rename this thread, because NFS wasn't really the issue at all...0
- 3K Nebula
- 222 Nebula Ideas
- 620 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 488 News and Release
- 108 Security Highlight
