NAS326 web gui stuck in NFS package update loop after fw update to 5.21
Mijzelf, i'd like to kiss you right now, that exactly sorted my box out!MetaRepo updated as you said and now it all looks more or less ok here!Glad I didn't reset as wouldn't have known what was wrong, I always prefer to fix if possible.Lessons..1) disable old packages before updating, especially if unofficial packages.2) remember packages are stored on the hdd, not internal! so pulling the hdd is a quick easy check.any more?huge thanks man!0
turns out FFP actually has a warning about removing it before firmware updates. Oops! I should have done that then. Because i hadn't used for years, I forgot what i'd already done.
I'll see if I can rename this thread, because NFS wasn't really the issue at all...0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
