firmware needed
madstokie
in Home Router
i have a ex3301-to using from lila connect, firmware on now is V5.50(ABVY.2)H0, is there a newer version than this one i have now, also under the maintenance there is no firmware update to access, any help would be great thanks
Hello @madstokie
V5.50(ABVY.3)C0 is due to come out in September 2022, see https://www.zyxel.com/support/Zyxel-security-advisory-for-multiple-vulnerabilities_Products.shtml
Since you have V5.50(ABVY.2)H0, which is an ISP customer version, then it would be worth you contacting your ISP lila connect to get a newer firmware when the C0 release comes out this month.
Kind regards,
Tony0 -
thanks for your reply tony, very helpfull1
- 588 USG FLEX H Series
- 477 News and Release
