How do I set working schedules for a specific client?
Best Answers
Hi, @RodukasHere is a way for you to achieve this requirement.
1. Turn off SSID Simple mode from the below path on Nebula:
Nebula >> Left Sidebar "Access point" >>SSID settings
2. Create a new SSID for your children and customize the SSID available time schedule for it by following the below path:Nebula >> Left Sidebar “Access point” >> SSID availability >> choose the SSID which is set for your children >> Enable SSID schedule and create a new schedule >> custom the time you want to restrict.
The SSID will only be available for the children during the time schedule that you set up.
Please refer to the link below for detailed information:
[NEBULA] How to configure SSID schedule? — Zyxel CommunityThank you.Zyxel_HsinBo
Hi @Rodukas,
The SSID schedule configuring is available for Base Pack users, you could set up this feature without any subscription!
Thank you.
Zyxel_HsinBo
Thank you for your response.
Unfortunately I do not see any SSID availability menu. I have the base pack version, is it a premium feature?0 -
Hi @Rodukas,
Thank you.
Zyxel_HsinBo
- 588 USG FLEX H Series
- 476 News and Release
