USG 100 Flex and German Magenta IPTV
Niro96
Niro96 Posts: 35
Hello, my USG 100 Flex is running very well so far. Unfortunately I can't get my IPTV to work. After these instructions I set everything. https://support.zyxel.eu/hc/en-us/articles/360004093659-IPTV-with-multicast-and-IGMP-USG-ATP-VPN-. Unfortunately the picture stops after 5 seconds. So when switching from unicast to multiast. Do you have another idea?
greeting
Marcus
«13
  • mMontana
    mMontana Posts: 1,248
    50 Answers 1000 Comments Friend Collector Fourth Anniversary
    Hello @Niro96 the document you linked has been updated 1 day ago. Does your settings reflect the latest versions?
    Moreover: are there any tech details about Magenta IPTV settings required on the service website?
    Consider that many forumers don't know German...
    Last but not least: your "player" device of IPTV is into LAN1 segment?
  • Niro96
    Niro96 Posts: 35
    Hello, thank you for your answer. I also implemented the new instructions. My IPTV sends the first 5 seconds. in unicast. Then in multicast. My IPTV also runs for 5 seconds. Then it stops. I think that the USG100 Flex cannot handle multicast and IGMPv3 properly.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 826
    50 Answers 500 Comments Friend Collector Second Anniversary
    Hi @Niro96
    Can you provide the reproduced video and packet files(that includes WAN and LAN interfaces while this symptom appears) to us via private message?
  • Niro96
    Niro96 Posts: 35
    I have sent a private Message. Marcus Henning
  • FelixSchneider
    FelixSchneider Posts: 35
    just turning in, I experience the same problem.
    Unicast works for 5 second but the switch to Muticast is never made.
    But bringing something new to the table Magenta TV needs IGMPv3 and SSM. So the only thing I can think of is that Source Specific Multicast does not work or isnt implementet.
    It seems from other implementations of SSM it schould be possible to enter the Source IP Address in the Upstrem IGMP Proxy, but this is not possible with USG FLEX Series.
    @Zyxel_Stanley, @Zyxel_Jeff
    I hope there is a final answer if Magenta TV is possible or not.
    Kind Regards
    Felix Schneider
  • Zyxel_Jeff
    edited October 2022
    Hi @FelixSchneider
    May I know what USG Flex device and its firmware version you are using? What is your ISP? Could you share your device config with us via private message? Please share your topology with us as well. Thanks.
  • Zyxel_Jeff
    Hi @FelixSchneider
    Moreover, could you capture complete WAN, LAN interface packets for us during IPTV runs for 5 seconds then it stops? Thanks.
  • FelixSchneider
    Will do that if I got the time, but could you please figure out if the USG FLEX Supports SSM ?
    @Zyxel_Jeff
  • FelixSchneider
    SSM - RFC Reference / Overview
    https://datatracker.ietf.org/doc/html/rfc3569
  • FelixSchneider
    edited October 2022
    For Reference which capabilities the Router must provide, see Section 5 of the following document...
    https://www.rfc-editor.org/rfc/rfc4607
Security Highlight
