freeze NAS542
how to do it , in detail please ?As your slot 1 kernel boots, and your slot 2 doesn't, it could help to auto boot the other kernel.
By exchanging the values of next_bootfrom and curr_bootfrom. The default startscript reads curr_bootfrom to decide which kernel to boot.
I did it .And the firmware from the recovery flash drive went.Attached is the log from the recovery flash drive." /env/config" has changed and now the start ends -Hit any key to stop autoboot: 1booting kernel of type uimage from /dev/nand0.kernel1.bbBad Header ChecksumFailed.booting kernel of type uimage from /dev/nand0.kernel2.bbBad Header Checksumwarning: No MAC address set. Using random address 1E:9B:53:E9:9E:FFT T T T0
I killed six hours today trying to connect to the board via ethernet ... no, no way ...So I'll look at the board. Bingo ! Torn off quartz resonator on the zero port of the ethernet !!! The dude who sold me the NAS apparently used a different port.there is good news1. finally everything works electrically.2 set up, learned and was able to connect via TFTP server)))Tomorrow I will try to raise the firmware ...
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
