XGS1930-52HP Switch port reset via cli
Hi @Tobihoby
Welcome to Zyxel community!
Since the XGS1930-52HP is a smart managed switch, it does not support CLI command.
You can use PWR cycle function to restart your PD(like CAM) via Web GUI.
Please go to Status > Neighbor and click the cycle button of the PD connecting port which you want to restart.
1. Click Neighbor
2. Click the cycle button of the PD connecting port that you want to restart. I use port 2 as an example.
Zyxel Melen1
Hi @Tobihoby
1. Click Neighbor
Zyxel Melen1 -
Prior to the Xs1930 every time I was uploading between 2.5Gbps and 1Gbps devices I was getting around 500 Mbps. Now with the XS1930 I can get the ful1 1Gbps or https://testmyspeed.onl/.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
