Mismatch in port numbering with snmp on GS1920
Hi everybody,
I'm monitoring my switches (GS1920-24HP and 48HP) in Observium or in Switchmap but there's a mismatch in the port numbering.
The numbering begins by "0", thus if port #5 is in vlan 200, it's shown that it's port #4 who is is that vlan in observium.
Has anyone experienced this problem ? Any suggestions to fix it ?
Thanks.
Hi Chris, I'm using Observium and Switchmap to monitor my switches.For the OID, I'm not very sure about what you're asking so I've export this 2 files with a snmp browser. Is that you're asking for ?Best regards.Freddy
Where shall I have to configure this setup ? In the monitoring software ?Regards.0
@millbull,
I'm not familiar with Observium of Switchmap, but based on the attached you have provided should use the OID/symbolic name witch has end with xxxxx.ifIndex and the type should be integer.Chris
Hi Chris,Observium and Switchmap are 2 different monitoring softwares.Since the problem appears on these 2 softwares, is there any way to make a change directly into the switches ?Regards0
Just to mention, the problem doesn't appear with the Cisco and HP switches, only with the Zyxel.
Hi @Millbull
Let me explain these 2 OID objects, they are both defined by RFC in RFC1213-MIB.
The definition of ifDescr is "A textual string containing information about the Interface…" It does not stipulate it must use port number. However, ifIndex has defined "A unique value for each interface. Its value ranges between 1 and the value of ifNumber…”, which we have to follow up it.
The different vendor has a different way to handle this, some of them choose ifDescr as their port number and some use ifIndex, hope you can understand.
Chris
Hi Chris,Thanks for your answer. I will try to solve my problem with these informations.Regards.Freddy0
- 396 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 83 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 915 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 912 Nebula FAQ
- 419 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
