USG Flex 100 - Nebula Control Center - Standalone GUI
CFlores
CFlores Posts: 10 image  Freshman Member
We just got a USG Flex 100 and got it online at the datacenter, and the fist question is.
- If i add the USG Flex 100 to the Nebula Control Center, can i get all the  functionality from the GUI i get when logged in locally to the device?
- Partial Functionality?
- If i add it to the NCC, can i still log in to the local GUI and get the settings from the image below?
Best Answers
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @CFlores,
    We will continue to enhance NCC
    Thank for your advice.
    Kevin
  • Zyxel_Kevin
    Hi @CFlores
    Unfortunately, It have to perform reset process if you want to revert to on-premise mode.
    Please feel free to contact us if you have concerns.
    Thank you
    Kevin
  • Zyxel_Kevin
    Hi @CFlores
    Welcome to the Forum, There is different management type between on-premise (local) and Nebula (Cloud). For Nebula mode, all settings will be done on the NCC.
    You can still log in to the GUI but it will not the same as on-premise, see the following sample.
    Kevin
  • CFlores
    edited June 2022
    So if i do add it to the NCC, i loose some functionality :/ seems a bad tradeoff
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    IMVHO you can't have feet on both stash.
    Cloud management of devices shifts the control center from the device to the cloud management.
    This allow easier deployment of devices and faster replacements, but to a price of leaving some border control on the table.
    Knowing if you need cloud or local management depends from several factor and... political choices.
  • Zyxel_Kevin
    Hi @CFlores,
    Kevin
  • CFlores
    If i move the USG Flex 100 to NCC and it does not work as i need it to, can i revert back to the original device interface without resetting the device to its factory configuration? i ask because its in the datacenter a few states away.
  • Zyxel_Kevin
    Hi @CFlores
    Thank you
    Kevin
  • mMontana
    Reserve your ticket and schedule downtime...
