GS1920-24HPv2: Disabling SNMP?
in my Homenetwork I am using a GS1920-24HPv2 Switch.
My question is: How can I disabling the SNMP because I have note found any disabling/deactivating option in menu "Management -> Access Control -> SNMP ->..."
The newest Firmware is running on this switch.
Thank you for your answer!
Hi @bandchef,
To disable SNMP, please go to Menu > Management > Access Control > Service Access Control to inactive SNMP.
Then go to the Status page, and you will see the SNMP is disabled.
Thank you for your answer. This has solved my problem.
I have another question:
If I also deactivate Telnet, SSH, FTP and HTTP, is it possible to connect the Switch via Browser by typing 192.168.178.2/login.html (192.168.178.2 is the IP-address of the switch!) in the address line of the browser (IE, Chrome)?
Hi @bandchef,
If you also deactivate Telnet, SSH, FTP and HTTP, then you are able to access your switch with HTTPS.
You can use "https:192.168.178.2" to access it.
But if you deactivate all of the services, you will not be able to access your switch.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
