xgs2210 I lost ip interface
@CCVO,
Could you please use Zyxel ZON utility to set IP address, if still not works then please screenshot the error message with your configuration file private message to me.1 -
Hello, ZON finds the switch. but does not react.
Can you restart the switch via the little clip-operated button?
I restarted the switch, I also injected an old configuration. the state does not change0 -
@CCVO,
Thanks for your update, could you screenshot the console error message also with the running configuration, please private message me, thanks.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
