IPSec VPN. How to create connection with multiple local and remote networks
Hello.
I Try configure IPSec with remote office. In connection settings I can add only 1 local and 1 remote network.
What should I do, if I have 3 networks:
10.80.6.0/24
10.80.10.0/24
10.80.12.0/24
Remote office has more networks:
10.88.12.0/24
10.76.0.0/16
10.10...
and etc.
10.80.6.0/24
10.80.10.0/24
10.80.12.0/24
10.88.12.0/24
10.76.0.0/16
10.10...
and etc.
Create multiple "Connections" on the same "Gateway".
5
5 -
Command line interface.If this arrangement sucks for you, sucks for me too, but it's the way that Zyxel request for making it work.I know there's a limit of tunnels (gateways) dependent from the device model, i don't know if there's a limit for subnets/connection/tunnel on the same gateway.0
Hi @bk1.
You also can add policy route for site to site VPN multiple subnet routing.0 -
@Zyxel_Cooldia might worth some example, if you could...Site1: subnet192.168.199.0/24Site2: subnets
172.31.99.0/24172.31.128.0/24172.31.158.0/24How can be implemented the policy routing on Site1 with only a 192.168.199.0/24 <> 172.31.128.0/24 VPN connection?
5 -
Hi @mMontana,
Thanks for the example.
In site 1, add policy route for subnet 172.31.128.0/24 routing.
src = 192.168.199.0/24
dst= 172.31.128.0/24
next hop = Site to Site VPN tunnel
In site 2, add policy route for subnet 192.168.199.0/24 routing.
src = 172.31.128.0/24
dst= 192.168.199.0/24
- 212 Nebula Ideas
- 549 USG FLEX H Series
- 341 Security Ideas
- 295 Service & License
- 469 News and Release
