UDP Flood issue (Zywall USG 100)
By chance... uPNP is enabled on the device?
I solved this issue!!!I appreciate your help and suggestions!I just turned ON the checkbox "Firewall" thus, port 53 closed automatically, and the active session pool became in a normal state!
Glad you solved. Which "Firewall" checkbox?
Turn ON the firewall at all.
I even disabled unused rules (like denying UDP packages).0 -
holy caramel mou!I was not seeing that coming!That made the world of difference....0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
