connect Qnap storage to Zyxel XS1930-12HP 10Gbit port
Hi!
Is ti possible to connect my Qnap storage with SFP+ port to Zyxel XS1930-12HP 10Gbit SFP+ port?
Can I use Zyxel DAC10G-3M-ZZ0103F for this purpose?
Some people report that it's for stacking only
Best regards, Stephen
  • StephenZweig
    StephenZweig Posts: 2
    Hi! Finally bought and tested the cable. It doesn't work.
    No link. Status is disconnected.
    Looks like the problem is on QNAP side.
  • Zyxel_Melen
    Zyxel_Melen Posts: 1,104
    Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Hi @StephenZweig
    Welcome to the Zyxel community!
    The DAC cable is not for stacking only.
    And I'm not sure if anyone has used Zyxel DAC10G-3M-ZZ0103F on Qnap storage, maybe you can wait for other users to share their experiences here.
    Melen
  • bymusty
    bymusty Posts: 15
    First Answer First Comment Friend Collector Nebula Gratitude
    Hi Stephen
    I used to connect with a dac cable in one of my clients, it works fine.
