My clients, mostly IOT devices are being disconnected daily NWA50AX
I have 2 NWA50AX access points
if I reboot the devices, everything reconnects. I've tried numerous things (unable to remember what, following advice on other threads etc)
really spoiling my experience now, things like thermostats are bing disconnected and I'm waking up to a cold house.
please help
please helpAnd... help also understand the community something more than your current dissatisfaction :-)
- describe in detailed way your network setup and AP configuration
- tell if there are surrounding network that might cause interference
- if there are any kind of Electromagnetic interfering devices like microwave or similar
- do maybe again some the things you've tried
0 - describe in detailed way your network setup and AP configuration
Network consists of, Virgin Media Router (type 4 hub), into a netgear switch, out to the 2 AP's, all wiredModem has an SSID, AP's have 4 SSID's between them, all different names of courseNo microwaves or similar sources of interference aroundone AP is upstairs, one AP is downstairs, typically 14-16 clients connect with 75/25 split favouring upstairs APall is connected again after rebooting the AP's but I'm expecting that they will drop again tomorrownot sure what your last comment meant, sorry0
4 SSIDs mean 4 different subnets or everything lies on the same network segment?Which is the channel configuration of the two APs?Are some schedules configured for network access?Is dynamic channel enabled? (DCS should be the name of the setting)0
I just setup 4 SSID's so whatever the default was, one is a guest, one is for IoT devices etc...both seem to be reporting channel 11 (DCS), signal seems strong with a wifi analyzer appyes some are configured to go off at midnight, but the ones that I have my clients in question connecting to remain on 24/7tried DCS both on and off0
Test 1 for starting:for every AP run a survey for rogue APs, and find which channel interval is less crowded.
Once found the correct channel space, pick for any of the APs one among these three channels: 1, 6, 11. Disable DCS, and configure the designed channel for the specific AP. Please, do not enable for these tests unless requested. The suggestion are referred to 2.4GHz which should be the most loved for the IoT devices.
All of the SSIDs should follow the current schedule.Three days without any issues won't be the "yay, we're good" but a good start. One day with issue is enough for try something different.Next step will be disable the schedules and allow 24/7 all SSIDs to work, with the same channel setup.0 -
OK cool, but how do I do this - "run a survey for rogue APs"
I do not have any NWA50AX and I do not use Nebula.Than, User manual is your best friendPage 85/261AP can scan for active networks that it can sense and report them into specific interface section.This helps you to understand better the environment of networks.
unfortunately that manual appears to be out of date. None of the menus match the interface I see with Nebyla. I can't find where to look for them but I think I can rule out rogue AP'sI've skipped to the next step and put the AP's onto channel 6 and disabled DCSI've also turned off 5ghz on the IOT SSIDlets see what happensthanks for you help so far0
Hi @m7urt
From your description, we know that your IoT devices often disconnected with your AP, and the SSID which IoT devices connecting with is active 24/7.
Besides, we also know that your signal strength is good, may I know how is the signal level (ex: -XX dbm) of your IoT devices?
You may check it at Nebula CC >> Access point >> Monitor >> ClientsFor more clearly identify your condition, we would also like to know your AP current firmware version and the event logs on Nebula CC when your IoT devices get disconnection.
Hi @mMontana
Thanks for your help. 😊
Kay
Kay
No disconnections today as far as I can tellBoth AP's are on firmware v6.29 (ABYW.1)Most clients are Orange or Green, I know I have a few that are out of the way that are fairly week but remain connected.0
- 385 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 74 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 334 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 886 Nebula FAQ
- 415 Security FAQ
- 228 Switch FAQ
- 198 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 63 Security Highlight
