My clients, mostly IOT devices are being disconnected daily NWA50AX
Same channel for both APs might be not the best option, let's see if it works.
i just switched one of the channels
Hi @m7urt
It’s happy to hear that no more disconnection happens again.
From your screenshot, we know that some of your devices, which connected with “BLACKGATE-IOT”, its signal level is below -65 dbm. To maintain a better WiFi performance, it is recommended to place your device and AP become closer, then get your device signal level above –65 dbm.
Besides, if you know that which channel is having a great interference that makes your network performance being worse, you can manually adjust the channel deployment to the less interference channel one-by-one. Otherwise, it is recommended to enable your DCS setting, it will help your AP dynamically scans the environment and choosing a less interference channel.
Here is an article about tips to let you get a better WiFi network,
Tips to help you improve your wireless network performance — Zyxel CommunityHope this get help with you.
Kay
Click this link to start: https://bit.ly/3R2Wx52
Kay
All gone a bit wobbly this morning
I'm rebooting
TASMOTA-T03 and TASMOTA-T09 have too low signal strength, IMVHO.
the reboot connects them all again
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
