USG 200 WAN with 2 Networks/VLAN
my provider send me some information how to connect by FTTH.
I am using an older USG 200 Security Gateway. I need to connect by pppoe without any vlan id to use internet. I am using wan1. This works great!
To use voip i need to setup a second connection on the same wan interface (wan1) but with  vlan id 2222.
How can i setup a second network on the same wan1 interface?
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 934  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    edited November 2022 Answer ✓
    Hi @Maik20
    Did you lost your IP address on wan2_ppp when enable vlan2222 ?
    Please kindly share your configuration file by private messages .
    Thank you
  • Zyxel_Kevin
    Hi @Maik20
    Greeting forum, Please kindly add the VLAN interface with VLAN ID 2222 and base wan1 port.
    Then you may test the VOIP connection. Thank you
    Kevin
  • Thanks alot. My phone is currently in lan1did i need an entry in the firewall settings to route vlan2222 to lan1? Later i like to move the phone to vlan40
  • Zyxel_Kevin
    Hi @Maik20
    In general, just check you have security policy to allow these traffic.
    But whether need other settings or not depends on your network architecutre.
    Kevin
  • Thanks for your help!
    I have added a vlan2222 on wan2 using dynamic ip. I got an ip from my internet provider on vlan222 10.8.x.x.
    But now my internet connection wont work any more. If i disable vlan2222 my internet connection works.
    I am using a pppoe connection on wan2 and setup a lan2 (port 3) on the usg2000 to add a voip-fone there.
    My provider uses two networks connected over one wan interface:
    no vlanid: internet
    vlan2222: voip
    I think my problem is the routing if i enable the vlan2222
    I never setup some special routes. I am using the firewall to restrict access to some vlans i am using for computer, guest, iot. I only have some routes for a vpn connection to our company (COMPANY_LAN). This is my routing table:
  • Zyxel_Kevin
    Hi @Maik20
    Thank you
  • Zyxel_Kevin
    Hi @Maik20
    After remove Trunk member vlan2222 internet access works now.
    For other problem, please send me the topology by private message/
    Thank you
    Kevin
