Cable diagnostics function XGS1930
Good morning,
I have tested cable diagnostics function on XGS1930 and i have found a strange result about Cable lenght result.
I have test a cable of about 1 m leght but the test function detect a lenght of 4 m.
I have repeated the test with a 15 m cable and the test result 22m.
If i repeat the test with the same cable the result doesn't change.
Why there is this different beetwen real lenght and mesaure lenght?
This is the example with 1 m cable:
@Alberto77,
It's related to the cable quality and the peer device also affected, can you please unplug the peer side cable and test it again, please refer to the "Distance to fault" this time.0 -
There is a 65m CAT.7 cable between a GS1900-8HP and a GS1900-24E.
The cable lengths in tech-support logfiles are 8HP: 75m, 24E: 95m
so I understand the length as an approach.
I have made a test with cable disconnected:
but the result is still wrong (the real lenght of the calbe is 1 m).
I also try the 15 m cable:
In this case the result is good.
@Alberto77,
The cable length will more accurate when it's up to 10 meters.0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
