backup password
tgo
When I upgraded my hard drive on my nas326 the capacity would not increase so I did a backup to external HD and deleted the volume and recreated it.
Now I am trying to restore and it is asking me password. I did not set up password for the backup. That I know.
Help.!!
Help.!!
Which software application do you use to backup the file?0
backup planner. That is the only backup software on the zyxel desktop.
Just checked backup planner by trying to create new backup. The password field is activated only if I choose the encrypt choice. Which I did not choose. Therefore I did not set a password. Why is it asking me and how can I restore my files?0
Any support staff on this question? I need to restore my data.0
Hi @tgo
You can check the schedule process of the backup.
Do you enable the encryption when doing the backup?
There are two types of file after done backup (.dar &.lst).
When restoring the data, if there is no encryption, it can directly get into the restore process without the pop up message ask for the password.
If you have seen the pop up message, it means you've enabled encryption when doing the backup.0 -
Thanks Jerry. 2 issues.
1. As I indicated above I did not enable encryption.
That is how I know I did not use password.
It was meant to be a quick deleting the volume and restoration job I didn't want/need encryption or password.
Since one is not activated without activating the other (which I checked) it seems unlikely I did it unknowingly.
2. I am not getting the backup in to the system to see or edit the schedule process. I deleted the entire volume and recreated it. Therefore I assume it is a completely new system. The backup file is in an external disk.
when I try to add it to the backup program, it is asking me a password.0 -
Curious also since it says "if you had protected the data with a password" the pop up must shows up even when one didn't use password.0
One more thing.
There are only .dar files and a file with only extension (.zydar_lock_file_BA11) file. No .lst file.
Hi @tgoWhen there is a .zydar_lock_file show in the backup folder, that means the backup process is not finished when doing the backup process.Normally when the backup is done, there should have two type of files in the folder.(.dar &.lst).And if there is no .lst file, the NAS could not do the restore without it.If the backup process is still exist, there is a way to get the data back if you've done the backup before with the backup jobs.However the volume is deleted, the backup job was removed by volume deleting, so you can no longer see the job in the list after you create a new volume, you may not get the data back.0
I had the same issue trying to recover data, looks like back up failed to complete. You will probably notice there isn't a file tree list when recovering.
You could try using the command line tool 'disk archive' I haven't had any luck with it yet. I can recover with it completed back ups but not incomplete ones0
- 441 Beta Program
- 292 Service & License
