SBG3600 not automatically switching to backup LTE
We have issue with SBG3600 that when our main internet connection is ETHWAN-SFP Down Active IPoE the system does not automatically route traffic through LTE Up Active XX.XX.XX.XX Cellular. Only after I reboot the router the backup LTE kicks in.
This is very counter productive to have "AUTO WAN" when it does not actually switch on the fly to the backup.
Is there anything we can do about this? Or is there some obvious configuration error I may have done and thats why it simple is idle until I reboot?
I can now confirm that updating to latest LTE version ahs fixed the issue. And setting the backup to PASSIVE is right way. Now it automatically does the changes as the main line drops it uses the LTE directly.
Hi @Cromfel
As my test result on AAKO.9 version, the internet connection will back in 30 seconds when SFP is disconnected.
You can go to check your multi-WAN setting.And check if any routing rules will effect outgoing traffic.
Thank you for the feedback!The problem with load balancing is that we can not have connections changing one request to 1 connection other to other connection. Only in the case where main connection is down, then we would like to have the LTE kick in. I'm not sure how your load balancing works e.g. it would be extremely detrimental if for a specific server data would be sent through different channels. This would be then detected as MITM attack on Bank servers as same cookies are coming from 2 different IP as if the communication was compromised? For different servers I suppose it could be fine to just stream one set of data one way and load balance other channels for other services with different servers or if sharding was used.Should the backup connection be set to passive?Or how to not use the load balancing all the time when all connections are up?0
Hi @CromfelIt's good heard your issue has resolved.0
Zyxel_Stanley said:Hi @CromfelIt's good heard your issue has resolved.
- 395 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 82 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 914 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 911 Nebula FAQ
- 415 Security FAQ
- 236 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 138 Service & License FAQ
- 72 About Community
- 62 Security Highlight
