MG-108 upload speed are limited to <400MPS
I am testing the 5G CPE on their mmWave throughput. I need to compare the performance on different PCs. When I use MG-108 the DL speed is perfect. But UL speed only 300+ MPS. My ISP has symmetric traffic flow which support 1G DL/UL. My connection is below:
1. ISP -> MG-108 -> PC
2. ISP -> PC
Test results are below:
1. DL 900 UL 300
2. DL 900 UL 900
I purchased 2 MG-108 and they behaved the same way. Any idea?
Thanks!
Weite
  • Zyxel_Melen
    Zyxel_Melen Posts: 1,104
    Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Hi @weitehuang,
    We have experienced some upload decrease cases and solved them by disabling the Green Ethernet Technology (EEE).
    Could you share your MG-108's serial number and the modem's model name with me?
    Or could you check if your modem supports the EEE function? If yes, could you disable it and test again?
    Melen
  • Hi Melen,
    Thanks for quick response! Here are my S/N
    1. S224324007867
    2. S224324007861
    My modem is a fiber optic modem (model BGW210 from AT&T/Arris). I browsed the settings but didn't see EEE is supported. Appreciate your help!
    Thanks!
    Weite
  • Zyxel_Melen
    Hi @weitehuang,
    Sorry for the late reply and thanks for your information.
    I will pm you for asking for your contact information so our local support will contact you.
    Melen
