Cannot sign into router even after factory reset
internetguy
I have a Zyxel EMG6726-B10A router that I've been trying to port forward, but every time I try and log in as an admin, the password I use (which is written correctly every time) won't work. After factory resetting the router, it still won't work. What's going on?
Hello @internetguy
The user guide at https://www.zyxel.com/global/en/support/download for EMG6726-B10A says that the password after factory reset is written on the label on your device.
Merry Christmas.
Kind regards Tony0 -
Yes, I am aware of this. However, the password still doesn't work after resetting. The user is admin, and the password is on the router, but the website says the password is wrong every time.tonygibbs16 said:Hello @internetguy
Merry Christmas.
I'm having the exact same problem with mine that's the same model.
- 588 USG FLEX H Series
- 476 News and Release
