AX7501-BO
Ijustneedsupport
in Home Router
Hi
I haven't had a chance to get human support through the website until now, I've been trying for weeks...
That's why I see writing to you here as a last resort.
Firstly, I need a password reset for my login for the box settings because I cannot log in there and secondly, I absolutely must have answered a question, Yallo is not helping me there and referred me to you.
(I have a yallo home fiber box: AX7501-BO)
How can I disable the WPA-3 security protocol (WPA-3 security key) on my WLAN router, on which WPA-3 and WPA-2 security protocols are activated?
My printer is only compatible with the WPA-2 security protocol.
I would be glad if you could, help me or forward my question to the right person.
Many thanks for your help.
With kind regards, A.
Hello @Ijustneedsupport
You could try https://support.zyxel.eu/hc/en-us/requests/new?ticket_form_id=114093996354 to open a ticket with Zyxel Networks support team.
Kind regards,
Tony1
Hello @Ijustneedsupport A,
Yallo say at https://support.yallo.ch/hc/en-gb/articles/4410483801105-Personalize-yallo-Home-Max-Fiber-Box- that the password is written on reverse side of your yallo Home Fiber Box.
Which device is providing your WiFi please?
- if it is the AX7501-B0 then you might be able to change it on there, but you should look to use WPA2 at least in order to have secure WiFi.
Unfortunately, the AX7501-B0 user guide is not able for free download, but you can register for it at https://service-provider.zyxel.com/emea/en/products/fiber-oltsonts/10g-active-fiber/hgus/ax7501-b-series under Downloads and Resources.
Kind regards Tony
Thank you. Yes, I know how to log in, but it doesn't work, so I need to reset the password, there is no option to do so.
Yes, the Yallo Box is: AX7501-B0, I don't know how to change the WPA without logging in, to the box settings...
How can I ask for a Password reset?
Because the one on the back of the router, unfortunately doesn't work anymore...
The only reason why I need all this is, because I need to change the WPA...
Thank you...0 -
Where can I contact the support? Please!0
Kind regards,
Tony1 -
Thank you very much!!!
Unfortunately, that doesn't work... I guess I tried already everything...
Really frustrating...0
- 397 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 78 Nebula Status and Incidents
- 5.1K Security
- 52 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 332 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 880 Nebula FAQ
- 415 Security FAQ
- 221 Switch FAQ
- 195 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 63 Security Highlight
