LTE5398-M904 finding sim but no internet connection
AndreL
in Home Router
Hello, today I tried my LTE5398-M904 but I encountered a problem:
After inserting the SIM, the router started up normally but only the led on power and wifi turned on.
I managed to go to the default page to configure the router and it said that the SIM is in the slot, but there's no internet.
I tried setting up manually the APN and rebooting but that didn't solve the problem.
I tried putting the SIM in my old router and it was working normally, I just noticed that there were some scratches on the SIM, could it be because I used and adapter from nano to micro SIM?
Also I'm from Italy, the operator of the SIM is "PosteMobile", but searching in some forums I found that other here in Italy have this operator with this router and don't have a problem.
The firmware installed is: 100ABQV2C0, the latest for this model.
Hello @AndreL
Are you able to post what is recorded in your System Log, which you should be able to export under System Monitor then Log in the menu of your LTE5398-M904 please?
Happy New Year.
Kind regards,
Tony0 -
Hello, I went to the log page but I just get an error. I'll post images from the screen.
I also tried to download the log anyway but it's just a blank page.
Update: I also tried with the SIM card from my phone: went to the setup page, inserted the PIN and unlocked the SIM but nothing, no connection.
At this point, cuold it be a hardware malfunction?
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
