Resolution dns
Frapla
Frapla Posts: 11
Hi all, I would like to know how to resolve the resolution of a domain name that must point to an internal ip. I configured in the dns but as a result it points to the firewall ip. Do I have to create some specific rule? can you help me please? Thank you so much
  • Frapla
    Frapla Posts: 11
    Thank you so much. ZyWall is set in dhcp dns how should i replace it? is that what causes me the problem?
  • WJS
    WJS Posts: 95
    edited January 24
    I suppose that your client's DNS is assigned by DHCP. Try to change DNS settings in DHCP server. ( interface -> DHCP)
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,296
    Hi @Frapla,
    You can switch from "ZyWALL" to "Custom Defined" to change DHCP client's DNS server.
    PeterUK Posts: 2,195
    100 Answers 1000 Comments Friend Collector Fifth Anniversary
    edited January 31
    You want to use Zywall so this happens.
    Maybe your using a VPN or browser with DNS over HTTPS?
Security Highlight
