Upgrading XGS-1210-12 firmware from a Mac ?
jb94220
jb94220 Posts: 2
I have tried to upgrade the firmware to the lates version via the web management pages but the switch does not seem to upload the firmware XGS1210-12_V1.00(ABTY.6)C0.bix - it uses C:\fakepath\XGS1210-12_V1.00(ABTY.6)C0.bix as file name file name, which obviously will not work on a Mac although the dialog box on the page allows me to go to the correct place where I saved the new firmware.
Is there a way to perform the upgrade ?
  • mMontana
    mMontana Posts: 1,248
    50 Answers 1000 Comments Friend Collector Fourth Anniversary
    If you're using Safari, try with Firefox or Chrome. The meaning of "fakepath" is simple. It's not important the path, the file is.
    I updated some old USG's firewall via Linux several years ago, using Firefox, without issues.
  • jb94220
    jb94220 Posts: 2
    Thanks a lot !
