GS1910-24 VLAN
Hi @Onur,The port VLAN configuration of Sophos firewall connecting port is recommended as below:1. Port VLAN should be "1" if your management VLAN is 1.2. Egress tagging should be "Untag port VLAN".3. Allowed VLAN should be "1,4"Also, the port VLAN configuration of end devices connecting ports are recommended as below:1. Port VLAN should be "4".2. Egress tagging should be "Untag port VLAN".3. Allowed VLAN should be "4"Hope it helps.Zyxel Melen0
The cable from the firewall is plugged into port 24. The computer with Windows is plugged into port 2. Management port is in vlan1.but windows computer is not getting IP
problem is solved. The problem was caused by the dhcp distribution being turned on.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
