[NEBULA] Is it possible to expose a web server to internet
Dear All,
We actually found the synchronize issue between the server and NSG NAT server, this issue will be fixed on next release in December, if you encounter any similar issue please contact us directly we have the workaround to fix it!
5
How about you pate the screenshot for your virtual server setting?0
I think this has something to do with the NSG reserving those ports for it's own management purposes.0
I ve just redirected HTTP and HTTPS from WAN to my server
Hello @sebala
Agree with @CrazyTacos
Those 2 ports has been reserved in order to access/manage the NSG GUI, I suggest to use the other ports like 8080 or 4443 instead of 80 and 443 as following screenshot
With this workaround, I cannot expose a formal web server. So, it doesn't solve my problem. :-(0
Hello,I will private messge you in order to do the further check, so stay tuned in the inbox.
Dear All,
5 -
Thank you Nebula_Chris, the workaround works great for me !Nebula_Chris said:Dear All,
We actually found the synchronize issue between the server and NSG NAT server, this issue will be fixed on next release in December, if you encounter any similar issue please contact us directly we have the workaround to fix it!2 -
could you please share the workaround in this forum or pm me? I am having the same issues with port 443 and 80 which I need for regular access to the web server behind my NSG300.
Thanks,
Walter0 -
Hi @blechkiste
As like the previous post since port 443 and 80 has been reserved, I suggest to use the other ports like 8080 or 4443 instead of 80 and 443 as following screenshot.
Could you please give a try on this and feel free to let me know the result, thanks.
- 588 USG FLEX H Series
- 477 News and Release
