Plex on a zyxel nas326?
  • Fksahin
    Fksahin Posts: 16 image  Freshman Member
    Hello @Mijzelf ; any idea to put m3u files on Plex iptv?
    I saw some articles for stand alone plex, however I didn't find any info for a plex which works on NAS326.
  • Mijzelf
    Mijzelf Posts: 3,013 image  Guru Member
    You'd better ask on a Plex forum, if such a thing exists. I only know how to install it, never used it myself.
  • Oscwo
    Oscwo Posts: 40 image  Freshman Member
    Is there a similar setup that is more suitabel for Zyxel that you know of?
  • Yolo45
    Yolo45 Posts: 13 image  Freshman Member
    Bonjour je suis noob sur le domaine des serveurs et j'ai rien compris aux explication serait il possible d'avoir de l'aide ?
    Comment installer MetaRepository ?
  • Mijzelf
    http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/
    Scroll down.
  • Yolo45
    alors je n'arrive pas a l'étape 2 quand il demande de télécharger le fichier zip
  • Yolo45
    bonjour désoler d'insister mais je comprend pas comment ont peut télécharger
    il n'y a pas de possibilité de télécharger
  • Mijzelf
    My french is a bit rusty, but I think you are saying that the firmware package manager fails in downloading MetaRepository. There are 2 possible reasons:
    • You have a wrong web_prefix file, or it is on the wrong place.
    • The NAS cannot reach to zyxel.diskstation.eu
    The second issue can be tested. Login over ssh on the NAS, and execute ‘ping zyxel.diskstation.eu’. It should respond.
    The first issue is harder. I can repeat the instructions on the page, but that won't add anything. So it's better that you tell what you did.
  • Yolo45
    j'ai cliquer sur le lien nas 326
    j'ai cliqué sur le fichier puis sur le 5.10
    comme indiqué j'ai crée un dossier zypkg
    et aprés rien ne se passe j'ai bien l'icone je clique dessus mais rien
  • Mijzelf
    That should be zy-pkgs. So when done there should be a file \\<NAS>\admin\zy-pkgs\web_prefix . That file is only a config file for the firmware package manager, which tells it to use the repository at “content of web_prefix” instead of the default one.
