Plex on a zyxel nas326?
vous devez définir le drapeau
que signifie ceci ?
bonjour alors comme vous me l'avez indiquer j'ai masqué les extensions maintenant que dois-je faire ?
When you have disabled the hiding of 'known file types', you should see the .txt or .doc extension of web_prefix, and you can remove it. The file shouldn't have an extension.
je n,'est pas bien compris
Well, I don't know what to say. The package manager looks for a file admin/zy-pkgs/web_prefix. If it exists, it will use the content as, well, a webprefix to exchange ftp://ftp2.zyxel.com/ . It will not check if there are files which have a similar name, or an extension.
If Windows Explorer says web_prefix is a text document, it probably has an extension, as AFAIK Explorer doesn't look into the file, only at it's extension. So you have to strip the extension, which you can't do if you can't see it. Open notepad, create a new file, and save it. As long as you can't see it's .txt extension, you have to fiddle with Explorer's settings until you can see it. And then look at web_prefix again.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
