Configuration converter seems not working
I am not able to have a converted configuration....
Steps to reproduce:
- download a startup-configuration from a 3.30 P3 USG20
- rename as DATE_USG20_330_site_startup-config.conf
- opened Configuration Converter in In Private Microsoft Edge 105
- selected "Zywall USG20 3.30" and "USG20-VPN 4.20"
- load the configuration
- clicked "copy all" ports (only LAN1 used)
- clicked "convert"
- page reload, only with the image header "Automated Configuration Migration Tool". Nothing more happens.
Chrome 105.0.5195.127 incognito : the same.Vivaldi 5.4.2753.51: the same.Firefox 32 bit 91.13.0 ESR: the same.Firefox 32 bit 102.3.0 ESR: the same.Firefox 64 bit 105.1.0: the same.Seems that ZyWALL Series Converter 2.0.8 is quite a non exiting converter.I use Sophos antivirus, may this be the issue?Edit: no.Edge, in private mode, no AV (Windows Defender), not even the header image loaded.
Hi @mMontana,
Thanks for issue report. We are checking this issue, will keep update status on this one.
Typo and my error here...Firmware release of the source device is 3.30(BDQ.9)ITS-WK48-r74988 / 1.17 / 2016-11-30 18:17:33. AFAIK the last LAB firmware available from Zyxel
Up. Sorry to bug again.In a couple of weeks I'm gonna have to upgrade three sites from USG20 to USG50 Flex. Oh, sorry, they call it USG20-VPN on boxes.Lacking of working configuration converter is a bummer, because for the upgrade to come trough I must re-do configuration from scratch on 5.31 version firmware. Hope to see soon updates.0
Thank you for your continued support. We will add this in a future improvement plan.If you have any questions about Converter or run into any problems with the conversion process, we’d be happy to help.0
seems to have same problem today again, converter from USG20 to USG20VPN (Flex50) not working instead of USG20 to USG40 is working perfectly with same startup config. could you fix this issue on the tool ?
I have the same issue from USG20 to USG20-VPN.
Also the converter do not specify if the (allegedely) converted configuration will be ok with ZLX 5.x firmwares.
@2ISR consider this experience before use the converted configuration. I'm having second, third and fourth guesses before do that again.
Hello, I need to convert a usg20 firewall configuration into a new usg20-vpn; I can't convert the file because the converter doesn't download the converted file. Anyone can help me? Thank you
I had to manually the configuration from USG20 to USG 50 flex, due to lack of 3.0 to 4.0 converter working. At least, this time I had none of the issues about the trial time wasted after using the converted configuration.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
