restrict device by mac address only to a certain switch
rstanila
rstanila Posts: 10
Hello
I have 4 switches managed in Nebula CC.
3 of them are connected to a main switch. This main switch also is connected to a router and internet.
How can I restrict one POE device (camera) to only one switch (one of the 3 above) ?
If by mistake I connect this POE device to any of the other 3 switches, I need the system to block the trafic.
  • Zyxel_Melen
    Zyxel_Melen Posts: 1,104
    Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Hi @rstanila,
    May I know which model are you using? It would be better for us to help investigate the solution.
    Melen
  • rstanila
    rstanila Posts: 10
    Hello
    we have the poe device connected to GS1915-8EP switch.
    the other 3 are GS1915-8EP, 1920- 24HP and 1920-48 HP
  • Zyxel_Melen
    Hi @rstanila,
    Apologise for the late reply.
    After investigation, Nebula could not provide you with a method to restrict a device that can only connect to a specific switch. However, the camera normally won't unplug and then plug into other switches after deployment. Is this requirement to prevent you connect the camera to the wrong switch during the deployment?
    Could you share more detailed information about your scenario?
    Melen
Nebula Tips & Tricks
