Zywall 110 to ATP200 converter
PlusAuto
PlusAuto Posts: 2
edited May 8 in Security
I`m in need to convert a config from a Zywall110 to ATP200. I cannot do this with the online converter tool.
Is there a way to do this easily ?
Kind regards,
Michel
    PeterUK Posts: 2,195
    100 Answers 1000 Comments Friend Collector Fifth Anniversary
    You can do it manually but it takes skill you have to be mindful of the interferers from one to the other.
    ….the other thing is passwords might not be copied over…
  • mMontana
    mMontana Posts: 1,248
    50 Answers 1000 Comments Friend Collector Fourth Anniversary
    https://community.zyxel.com/en/discussion/16514/usg-flex-100-w-built-in-ap-not-comply-with-the-config
    https://community.zyxel.com/en/discussion/13622/usg60w-to-usg-flex-100w-configuration-conversion
    Please, read my experience before considering viable the conversion of the configuration…
  • Zyxel_James
    Zyxel_James Posts: 467
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    Yes, ZyWall 110 is only able to converter to USG FLEX 500 or VPN100 on our Online converter.
    You can provide your config to me through PM, I will do it for you.
    James
  • Zyxel_James
    Hello @PlusAuto, the converted ATP200 configuration is sent through our PM, please check, thank you.
Security Highlight
