Flex 200 and public web server
I have a new Flex 200 and it's all set up and configured. I have NAT/Sec Policies for SIP and SSH working as expected, but I can't get Remote Desktop Services and a WEB server accessible from the outside. Note - the RDS is coming in on a different public IP than the web server so I have NAT policies for each of the two IPs sending that traffic to their respective private servers.
I created address objects and wrote NAT policies and Security Policies for the WEB server and I can't access it externally.
The Flex is managed on 8443 so I don't think that's my issue. I'm getting a
Match default rule, DNAT Packet, DROP
error in the log. It's for a Security Policy so I'm thinking I'm missing something in the sec pol, but I can't figure out what it is.
Anyone have any ideas?
New INFO: If I switch the default rule to allow, I get an error that I've exposed the mgt interface and the SSLVPN to access from the internet so I'm pretty sure it has something to do with that.
Maybe you need to change the SSLVPN port too? VPN > SSL VPN > Global setting tab
you then need Policy Control from WAN to LAN
SSLVPN is already set to 9443 and I do have a policy set to allow https traffic on the public IP directed to the web server.
I added the WAN to LAN1 policy and it's working. Thank you.
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
