USG20-VPN Crash
hi,
exactly same case here !!!
either usg20 in 5.30 or 5.35
If you have got a known good backup of all the settings for your USG20-VPN from before the problem started, you may want to factory reset your device, then reload the config and reboot to see if it helps. Not sure if there is a limit to log storage or if that is even an issue on your device.
Following the incident that occurred this morning, we would like to provide our feedback. Several of our clients experienced a loss of VPN connection. The issue had various consequences for the clients, including incorrect password for the graphical interface, slow graphical interface performance, and VPN unavailability. In order to resolve these issues for all clients, we recommend performing a software update on the Zyxel device and restarting it.
Thank you for all your valuable feedback. We are actively working on this issue and developing a new firmware version specifically for this case. As soon as the firmware is ready, we will provide an update in this thread. We appreciate your patience and cooperation.
We are experienced the same issues on USG FLEX 100 & USG FLEX 200.
Firmware 5.36(ABUI.1)C0, changed by 5.35(ABUH.0) but the problems are the same : Impossible to acces GUI Admin, VPN Disconnected.We wait a solution.
The issue has fixed by firmware. You can download firmware by this thread.
There is no USG 20 VPN Firmware
There is NO USG20 VPN Firrmware
Not sure whats needed for the attack to happen but if you don't use VPN are you blocking VPN services to Zywall? Maybe get a swtich with ACL to drop VPN services getting to Zywall?
If you use a VPN can you DDNS each side and allow VPN services from that DDNS each side? Or use a switch with ACL to allow given IP's to Zywall for VPN services and drop the rest.
I have the same problem since yesterday with a USG FLEX 20VPN.
The IPSEC cuts off it works again after restarting but it replants a few minutes later.
I also lose access to the interface but I keep access to the network.
No modifications have been made to this FW for a long time.
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 923 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 212 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 72 About Community
- 62 Security Highlight
