App watch dog recover sshipsecpm dead
2
  • dpipro
    dpipro Posts: 61
    First Comment Friend Collector Fourth Anniversary ZCNE Switch Level 1 Certification - 2020
     ZCNE Certified
    @Remon @Tobias can you describe the workaround solution? Thank you
    Best regards
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,296
    100 Answers 1000 Comments Friend Collector Fifth Anniversary
    Thank you for all your valuable feedback. We are actively working on this issue and developing a new firmware version specifically for this case. As soon as the firmware is ready, we will provide an update in this thread. We appreciate your patience and cooperation.
  • Remon
    Remon Posts: 6
    This is it:
    You need to create the following rules:
    Then:
    Do not have it enabled at first.
    Move the rule to a positiion after the allow rule.
    Then enable the rule.
    This should resolve the issue for now.
  • Zyxel_Tobias
    Zyxel_Tobias Posts: 200
    5 Answers First Comment Friend Collector Fourth Anniversary
    Please don´t use workaround for now, it may make more trouble in future :)
    We will update this thread quite soon with better solution steps.
  • 6ilvio
    6ilvio Posts: 2
    We experience the same issues on USG FLEX 100 & USG FLEX 200.
    Firmware 5.36(ABUI.1)C0, changed by 5.35(ABUH.0) but the problems are the same : Impossible to acces GUI Admin, VPN Disconnected.
    We wait a solution.
  • nov_zyxel
    nov_zyxel Posts: 1
    edited May 23
    Same issues for us, with many USG210, USG310, Flex200, firmware up to date.
    VPN IPSEC go down after a few minutes… many customers impacted
  • Hi, Same Issues for us. Differents Models impacted. Firmware Up to Date. VPN Disconnect / reconnect after maximum 900s
  • Spyrtsat
    Spyrtsat Posts: 1
    Same issue here on USG110, on the latest firmware. VPN connections drop after around 15 minutes.
  • Zyxel_Stanley
    The issue has fixed by firmware. You can download firmware by this thread.
  • Akran
    Akran Posts: 1
    I have a USG FLEX 200 on nebula cloud how do I update manually?
Security Highlight
