USGFLEX50 firmware upgrade
savino
savino Posts: 3
Hi, I have a USGFLEX50 that needs to be updated.
Current firmware is V5.30(ABAQ.0)
I tried to upload the versions:
5.36(ABAQ.2) or 5.32(ABAQ.0) or 5.31(ABAQ.0),
but I always get the same message Firmware not compatible.
How can I solve the problem.
Thanks !
Best Answers
  • mMontana
    mMontana Posts: 1,248
    50 Answers 1000 Comments Friend Collector Fourth Anniversary
    Did you try to reboot your firewall before try to upgrade standby partition?
  • Zyxel_James
    Zyxel_James Posts: 467
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    Please try to boot up with the standby partition and upgrade the firmware for the original running partition.
  • savino
    savino Posts: 3
    Solved,
    "boot up with the standby partition and upgrade the firmware for the original running partition"
    Thanks for your help
Security Highlight
