Broudcast 224.0.0.1 von dem Gateway vor Zyxell Flex 100 schreibt log voll
[Deleted User]
[Deleted User] Posts: 9  Freshman Member
Geräteanordnung
ISP - DigiBox(10.0.0.1) - Zywall(10.0.0.100;192.168.2.1) -
Im log taucht folgendes auf
… 10.0.0.1 224.0.0.1 notice secure-policy ACCESS BLOCK Match default rule, DROP
Ich habe diverse Regeln eingefügt,
zB habe ich Source 10.0.0.1 bzw. Destination 224.0.0.1 geblockt, also eine entsprechende Policy eingefügt, nur werden die Zeilen weiter ins Log geschrieben.
Wie kann ich den Multicast Eintrag vermeiden?
thx
Chris
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 958  Guru Member
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @Rogge ,
    Greeting Forum, Please kindly share your diag-info by private message.
    Thank you
  • [Deleted User]
    Hi Kevin,
    padon, what do you mean with diag-info?
    one Log entry every 2 minutes:
    4    2023-06-06 00:01:39 10.0.0.1                                        224.0.0.1     notice              secure-policy          ACCESS BLOCK     Match default rule, DROP
    I also used WAN for from, and 10.0.0.1 for Source, but still entries in the log files.
    thx
  • [Deleted User]
    ok, found diag-info.
    I will update later, remote not feasible for me.
  • Zyxel_Kevin
    Hi @Rogge ,
    The IGMP logs will be defined as debug level logs. Please kindly check "Security Policy Control" log level is normal.
    Thank you
  • [Deleted User]
    Hi Kevin, it is normal
  • [Deleted User]
    the trick was to use ZyWall for „to“ instead of any(Excluding ZyWall)!!!
    thx Kevin!
