USGFLEX50 firmware upgrade
Hi, I have a USGFLEX50 that needs to be updated.
Current firmware is V5.30(ABAQ.0)
I tried to upload the versions:
5.36(ABAQ.2) or 5.32(ABAQ.0) or 5.31(ABAQ.0),
but I always get the same message Firmware not compatible.
How can I solve the problem.
Thanks !
Best Answers
Did you try to reboot your firewall before try to upgrade standby partition?
Please try to boot up with the standby partition and upgrade the firmware for the original running partition.
Solved,
"boot up with the standby partition and upgrade the firmware for the original running partition"
Thanks for your help0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
