Migrate configuration
RikHead
RikHead Posts: 5
Hello everyone, I will be grateful to anyone who can help me with this:
I'm trying to migrate the configuration from a USG 110 to a USG FLEX 200. Is there a quick way to convert the old configuration backup to a new one?
Regards
  • Zyxel_James
    Zyxel_James Posts: 467
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    Hello @RikHead
    Our online converter could transfer the configuration from USG110 to USG FLEX 500. You may transfer it to USG FLEX 500 first, and then manually adjust it to the configuration of USG FLEX 200.
    You can provide it to me through private message, and I will do it for you.
  • RikHead
    RikHead Posts: 5
    Thanks for answers, i tried but it doesn't work. I patched the old USG110 to the new 4.73(2) firmware version, i do the same thing to the last one version in USG FLEX 200 device. There is a step by step guide to import old firewall configuration into the new?
  • Zyxel_James
    @RikHead
    Do you encounter anything with the steps below
    1. Please backup the configuration on USG100 4.73P2
    2. Convert the configuration to USG FLEX 500 via online converter
    3. Manually adjust the configuration to USG FLEX 200
    4. Upgrade the USG FLEX 200 to the latest version 5.36P2.
    5. Upload the configuration to USG FLEX 200.
    May I know how it failed? upload configure fails?
    You can send the configuration to me through private message, I will do it for you.
    James
Security Highlight
