USG FLEX 100 DROPS CONNECTION
Good afternoon,
Today I've setup a Flex 100 at a customers premises with default settings and static IP on the WAN port as given by the ISP.
The customer wants to mostly use the device as a VPN router to allow a few tablets to connect to the network and use a business application. I've setup 5-6 local users and went through the quick setup to create a new StrongSwan profile and all worked fine.
After a few hours the customer called me and told me that the internet and the local network was not working. I asked him to try to access the firewall using the local address but nothing happened.
I visited the premises and I found out that if the WAN was connected, the firewall would drop all connections and not work. I disabled policy control and everything works fine but I don't want to leave it like that.
Any ideas what might have gone wrong? Attached are the rules that are currently disabled.
Is the firmware upto date?
Hi @ckassianides ,
Gretting forum, Please kindly your firewall have up to date.
And please provide diag-info by private message. I will check that.
Thank you
I updated it after I disabled the policy control but I haven't enabled them back. I will probably do it later tonight so that they can at least get through the working day.
As far as I know, the logs are erased when the machine is restarted. is that not true?
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
