sfp wan atp100
leonardo
leonardo Posts: 7
edited July 5 in Security
Can I configure port sfp octical whith module Gpon ?
for wan access?
the vlan is 835 for date
836 for voice and 3552 for multivideo
the ISP is tim with adsl FTTH
  • leonardo
    leonardo Posts: 7
    the Vlan to configure to por sfp gpon - via WAN
    User Vlan Dati 835
    User Vlan Voce 837
    User Vlan Video 836
    Vlan Gpon Dati 100
    Vlan Gpon Voce 101
    Vlan Gpon Video Multicast 3585
    Tipo Segnale Ottico GPON
  • leonardo
    leonardo Posts: 7
    Schema a blocchi di una rete GPON. Vengono utilizzate, nel complesso, tre diverse lunghezze d’onda: 1490 nm per la ricezione, 1310 nm per la trasmissione e 1550 nm per i servizi in overlay.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 826
    50 Answers 500 Comments Friend Collector Second Anniversary
    Hi @leonardo
    Do you want to configure VLAN interfaces on the SFP port, right? If so, will the SFP port belong to WAN or LAN role? If you could share the topology with us and that would be better. Thanks.
  • MJStar
    MJStar Posts: 33
    @leonardo
    Maybe you could refer to this similar discussion for the VLAN settings on the SFP port and you could configure VLAN tag on the WAN port of SFP interface as well.
  • leonardo
    leonardo Posts: 7
    I would like to use the SFP gpon module of the ATP100 to connect directly to the FTTH ADSL line....
  • leonardo
    leonardo Posts: 7
    the atp100 will be ONT (optical network terminationi) at home
  • Zyxel_Jeff
    Hi @leonardo
    If you configure VLAN ID on the SFP wan port and the outgoing traffic would be tagged the VLAN ID only, as below:
    But if you want to prioritize voice, video, or other specific traffic, we suggest you could use the BWM feature. Thanks.
Security Highlight
